Sites ou fournisseur pour pieces land rover
Merci Alex mais non c'est pour mon def !!!!
Ok
mais renseigne toi dans un comptoir mecanique, on a souvent des bonnes surprises
je me renseignerais mais 4x4 Normandie ma sortie des prix a 10 20euros le roulements donc je pense pas m'embêter mais c'est a vérifier.
jeeper eagle
jeeper eagle
Bjour pour ref nombre VIN et annees
pont LR demonter avant Salisbury demonter arriere
joint spi --oil seal roulement differential----bearing differential roulement pinion interior--inner exterior ---outer
roulement roue---wheel bearing
catalogue Rimmer bros
Differential Assembly - New Original 2 pinion - 10 spline halfshafts
up to VIN KA930455 (1993) 1 FTC2750 Out of stock. Add to cart and Back Order or
Notify Me! When available
£967.69 ex VAT
£1,161.23 inc VAT
Exchange Surcharge
£540.00 ex VAT£648.00 inc VAT
Price Match
Qty:
Differential Assembly - Factory Reconditioned 2 pinion - 10 spline halfshafts
up to VIN KA930455 (1993) 1 FTC2750E Out of stock. Add to cart and Back Order or
£640.16 ex VAT
£768.19 inc VAT
Exchange Surcharge
Price Match
Qty:
Differential Assembly - Reconditioned Aftermarket 2 pinion - 10 spline halfshafts
up to VIN KA930455 (1993) 1 FTC2750R Available to Order. Order NOW!
£336.38 ex VAT
£403.66 inc VAT
Exchange Surcharge
£75.00 ex VAT£90.00 inc VAT
Price Match
Qty:
Differential Assembly - New Original 2 pinion - 24 spline halfshafts
VIN LA930456 (1994) on 1 FTC5142 No Longer Available USE TBB000250
Differential Assembly - New - Genuine Land Rover
1 TBB000250 No Longer Available USE LR027943
OEM - Differential Assembly - New 2 pinion (24 spline halfshafts)
VIN LA930456 (1994) on 1 TBB000250P1 Available to Order. Order NOW!
£445.83 ex VAT
£535.00 inc VAT
Price Match
Qty:
Differential Assembly - Aftermarket
1 FTC5142P Available to Order. Order NOW!
£466.67 ex VAT
£560.00 inc VAT
Price Match
Qty:
Differential Assembly - Genuine Land Rover
1 FTC5142R Out of stock. Add to cart and Back Order or
£348.15 ex VAT
£417.78 inc VAT
Exchange Surcharge
£100.00 ex VAT£120.00 inc VAT
Price Match
Qty:
Differential Assembly - Factory Reconditioned - Genuine Land Rover 2 pinion - 24 spline halfshafts
VIN LA930456 (1994) on 1 FTC5142E Out of stock. Add to cart and Back Order or
£282.15 ex VAT
£338.58 inc VAT
Exchange Surcharge
Price Match
Qty:
Differential - Rear - 4 Pin - New
1 TBB100980 Out of stock. Add to cart and Back Order or
£1,312.12 ex VAT
£1,574.54 inc VAT
Exchange Surcharge
Price Match
Qty:
Differential - Rear - 4 Pin - Aftermarket
1 TBB100980P No Longer Available USE TBB100980
£1,312.12 ex VAT
£1,574.54 inc VAT
Exchange Surcharge
Price Match
Qty:
Gasket - Differential Housing standard axle
up to 1994 VIN LA 1 7316 No Longer Available USE 7316P
Gasket - Differential Housing - Aftermarket
1 7316P In stock
£0.47 ex VAT
£0.56 inc VAT
Price Match
Qty:
Gasket - Differential - Salisbury Axle - Genuine Land Rover
up to 1994 VIN LA 1 RTC1139 In stock
£5.32 ex VAT
£6.38 inc VAT
Price Match
Qty:
Gasket - Differential - Salisbury Axle - Aftermarket
1 RTC1139P In stock
£0.79 ex VAT
£0.95 inc VAT
Price Match
Qty:
Silicone Sealant - Genuine Land Rover used instead of gasket
VIN MA (1995) on 1 RTC3254 Out of stock. Add to cart and Back Order or
£10.08 ex VAT
£12.10 inc VAT
Price Match
Qty:
Silicone Sealant - Aftermarket
1 RTC3254P In stock
£7.71 ex VAT
£9.25 inc VAT
Price Match
Qty:
Oil seal - Genuine Land Rover
up to VIN VA102732 1 FRC8220 In stock
£20.86 ex VAT
£25.03 inc VAT
Price Match
Qty:
Oil Seal - Differential Pinion - Aftermarket
1 FRC8220P In stock
£1.17 ex VAT
£1.40 inc VAT
Price Match
Qty:
VIN VA102733 on 1 FTC5258 In stock
£9.97 ex VAT
£11.96 inc VAT
Price Match
Qty:
1 FTC5258P In stock
£1.76 ex VAT
£2.11 inc VAT
Price Match
Qty:
Oil Seal - Differential Pinion - Salisbury Axles - Genuine Land Rover
up to VIN WA159806 1 AEU2515 In stock
£19.37 ex VAT
£23.24 inc VAT
Price Match
Qty:
Oil Seal - Differential Pinion - Salisbury Axle - Aftermarket
1 AEU2515P In stock
£2.58 ex VAT
£3.10 inc VAT
Price Match
Qty:
VIN XA159807 on 1 STC4401 Out of stock. Add to cart and Back Order or
£31.62 ex VAT
£37.94 inc VAT
Price Match
Qty:
1 STC4401P In stock
£5.00 ex VAT
£6.00 inc VAT
Price Match
Qty:
Bearing - Pinion outer
Rover Axle - All exc 110/130 4 Pinion 1 539707 In stock
£10.61 ex VAT
£12.73 inc VAT
Price Match
Qty:
Bearing - Pinion - Aftermarket
1 539707P In stock
£6.46 ex VAT
£7.75 inc VAT
Price Match
Qty:
Bearing - Genuine Land Rover
Rover Axle - All exc 110/130 4 Pinion 1 539706 Out of stock. Add to cart and Back Order or
£36.79 ex VAT
£44.15 inc VAT
Price Match
Qty:
Bearing - Pinion - Inner - Aftermarket
1 539706P In stock
£5.42 ex VAT
£6.50 inc VAT
Price Match
Qty:
Rover Axle - All exc 110/130 4 Pinion up to VIN KA 2 RTC2726 Out of stock. Add to cart and Back Order or
£31.53 ex VAT
£37.84 inc VAT
Price Match
Qty:
Bearing - Differential - Aftermarket
2 RTC2726P In stock
£2.95 ex VAT
£3.54 inc VAT
Price Match
Qty:
OEM - Differential Bearing - Side
2 RTC2726P1 Available to Order. Order NOW!
£7.76 ex VAT
£9.31 inc VAT
Price Match
Qty:
Rover Axle - All exc 110/130 4 Pinion VIN LA930456 2 RTC3095 Out of stock. Add to cart and Back Order or
£35.50 ex VAT
£42.60 inc VAT
Price Match
Qty:
Bearing - Differential Pinion - Aftermarket
2 RTC3095P In stock
£3.50 ex VAT
£4.20 inc VAT
Price Match
Qty:
Rover Axle - 110/130 4 Pinion 1 539707 In stock
£10.61 ex VAT
£12.73 inc VAT
Price Match
Qty:
1 539707P In stock
£6.46 ex VAT
£7.75 inc VAT
Price Match
Qty:
Bearing - Pinion Bearing - Inner - Genuine Land Rover
Rover Axle - 110/130 4 Pinion 1 607180 Out of stock. Add to cart and Back Order or
£61.75 ex VAT
£74.10 inc VAT
Price Match
Qty:
Bearing - Pinion Bearing - Inner - Aftermarket
1 607180P In stock
£10.62 ex VAT
£12.74 inc VAT
Price Match
Qty:
Bearing - Differential - Genuine Land Rover
Rover Axle - 110/130 4 Pinion 2 607187 Out of stock. Add to cart and Back Order or
£60.44 ex VAT
£72.53 inc VAT
Price Match
Qty:
2 607187P In stock
£5.00 ex VAT
£6.00 inc VAT
Price Match
Qty:
Salisbury Axles 1 UKC978 In stock
£20.21 ex VAT
£24.25 inc VAT
Price Match
Qty:
Nut - Genuine Land Rover
Standard Axle 1 3259 Out of stock. Add to cart and Back Order or
£2.48 ex VAT
£2.98 inc VAT
Price Match
Qty:
Castle Nut - Pinion Flange - Aftermarket
1 3259P Available to Order. Order NOW!
£1.33 ex VAT
£1.60 inc VAT
Price Match
Qty:
Nut M16 - Genuine Land Rover pinion flange
Standard Axle 1 NY116041L In stock
£1.70 ex VAT
£2.04 inc VAT
Price Match
Qty:
Nut M16 - Aftermarket
1 NY116041LP In stock
£1.08 ex VAT
£1.30 inc VAT
Price Match
Qty:
Nut - Pinion Flange - Genuine Land Rover
Salisbury Axles 1 90608545 Out of stock. Add to cart and Back Order or
£11.91 ex VAT
£14.29 inc VAT
Price Match
Qty:
1 90608545P In stock
£5.83 ex VAT
£7.00 inc VAT
Price Match
Qty:
Split pin - Genuine Land Rover
1 PS608101L In stock
£0.22 ex VAT
£0.26 inc VAT
Price Match
Qty:
Split Pin - Pinion Flange - Aftermarket
1 PS608101LP In stock
£0.12 ex VAT
£0.14 inc VAT
Price Match
Qty:
Gasket - Pinion Flange - Genuine Land Rover
Salisbury Axles Only 1 607183 In stock
£0.75 ex VAT
£0.90 inc VAT
Price Match
Qty:
Washer-Thrust - Genuine Land Rover
4 607168 In stock
£2.24 ex VAT
£2.69 inc VAT
Price Match
Qty:
Washer-Thrust - Aftermarket
4 607168P In stock
£1.33 ex VAT
£1.60 inc VAT
Price Match
Qty:
2 607169 Out of stock. Add to cart and Back Order or
£2.44 ex VAT
£2.93 inc VAT
Price Match
Qty:
2 607169P In stock
£1.83 ex VAT
£2.20 inc VAT
Price Match
Qty:
Washer Thrust - Genuine Land Rover
1 607182 In stock
£2.02 ex VAT
£2.42 inc VAT
Price Match
Qty:
90-110 et différencié Défenseur - arrière
Il existe 2 types d'essieu arrière monté sur le Land Rover:
1. L'essieu conventionnelle Rover, dont le différentiel est retiré comme une unité complète sur le devant de l'essieu.
2. L'essieu de Salisbury, qui a une plaque d'accès à l'arrière de l'essieu pour le retrait différentiel.
Essieux Rover ont deux types de différentiels, comme suit:
2 pignon (la norme de service) ou 4 pignon (heavy duty), se référant au nombre de pignons dans le différentiel lui-même.
Véhicules équipés avec 2 pignon diff ont 10 spline demi-arbres à NIV KA930455 (1993), et 24 demi-arbres de spline à partir de VIN LA930456 (1994) sur.
Véhicules à quatre pignons diff sont tous équipés de 24 demi-arbres de spline.
Les clients ayant acheté cet article ont également acheté
Land Rover - écran thermique Assy - Genuine
£ 29.45 HT £ 35.34 TTC
Commander
bil76
bil76
sacree pointure notre jeeper eagle Very Happy
Voila c'est j'ai commandé chez http://www.landers-shop.fr/index.cfm !
J'ai eu le mec au téléphone, y sont sérieux apparemment .
Question tarif y a des pièces plus cher et d'autre moins donc ca s'équilibre surtout que j'ai 13% de remises et les frais de port offert soit 50e de gagné.
On verra a la réception ce que ca donne, 1semaine de délai.
